Add TriggerClick to extension widget
  • January 27, 2023
  • 3 replies
  • 1661 views
Hello All,
I have create an extension widget already and I want to add TriggerClick like default ptcs-button to my extension widget
please suggestion
thankyou
Best answer by nmutter
Hey Chanin,
feel free to get inspired from my extension. I have to events defined 'ClearSelectedRows' and 'SelectAllRows'. See code here https://github.com/doubleSlashde/InfotableInspectorWidgetTWX/blob/main/ui/infotableinspector/infotableinspector.ide.js#L42
and the other files
Hope that helps!
Hello @Chanin
Can you pls share the version of ThingWorx that you are using?
Regards
Bhawna
Chanin13-AquamarineAuthor
Hello @bchaudhary_448008
I'm using Thingworx version 8.5 and Eclipse IDE to compile the widget.
Please suggest and thank you for your replay
Regrads
Chanin
7-Bedrock
March 2, 2023
Hello @Chanin ,
Can you please provide me little bit more details on your request please. Are you trying to setup the default button that triggered on particular event? If possible can you please send me the Test XML file of the Mashup.
Waiting for your kind reply.
Thanks & Regards,
Surbhi Patel
I can already add a triggerClick in extension widget, anyway thanks you sir.
nmutter16-PearlAnswer
Hey Chanin,
and the other files
Hope that helps!
thanks you @nmutter, i can add triggerClick already.
