AddPropertyDefinitions Not Working
travman7777
I am trying to utilize the AddPropertyDefinitions function to add multiple properties to a thing.  However I am unsuccessful.  I am able to individually add a property by using AddPropertyDefinition, however when I try and using AddPropertyDefinitions the properties are not added.  Is this a bug with the function or is there something wrong in my code.  I have attached an exported file of the Thing/Service for reference.
Using TWX 9.1
Hi there,
Firstly I think you should use name "baseType" instead of "type" when specifying property type
Secondly there is a missing semicolon after "let turnedOn = {...}"
Could you please try again after making above adjustment in your service see how it goes?
Tony
Hi there,
Tony
Hi Tony,  Changing type to baseType fixed the issue.  Good catch.
