AddPropertyDefinitions Not Working
travman7777
9-Granite
I am trying to utilize the AddPropertyDefinitions function to add multiple properties to a thing.  However I am unsuccessful.  I am able to individually add a property by using AddPropertyDefinition, however when I try and using AddPropertyDefinitions the properties are not added.  Is this a bug with the function or is there something wrong in my code.  I have attached an exported file of the Thing/Service for reference.
Using TWX 9.1
TonyZhang
(To:travman7777)
Hi there,
Firstly I think you should use name "baseType" instead of "type" when specifying property type
Secondly there is a missing semicolon after "let turnedOn = {...}"
Could you please try again after making above adjustment in your service see how it goes?
2 REPLIES 2
TonyZhang
(To:travman7777)
Hi there,
Hi Tony,  Changing type to baseType fixed the issue.  Good catch.
