AddStreamEntries Problem
lwei
Hi Developers!
     I have two streams, A stream and B stream, and their data shape are the same.
I've tried to add a part of stream data from A stream to B stream by using service addstreamentries.
But it kept saying Wrapped java.lang.NullPointerException Cause: null
Can someone help me? Appreciated!
Lee
3 REPLIES 3
ttielebein
(To:lwei)
Hello, can you please provide the JavaScript syntax you are using to attempt this copy?
lwei
(To:ttielebein)
var params = {
  oldestFirst: undefined /* BOOLEAN */,
  maxItems: undefined /* NUMBER */
// result: INFOTABLE dataShape: "undefined"
var a = me.GetStreamEntriesWithData(params);
var params = {
  values: a /* INFOTABLE */
// no return
Things["BStream"].AddStreamEntries(params);
ankigupta
(To:lwei)
Hi Lee Wei​,
The output format for GetStreamEntriesWithData service and the input format for AddStreamEntries service is different.
Please refer to following Blog for your answer to your query: How to copy entries from one Stream to other Stream
I hope it helps.
