Adding a state definition to a button
Janicen
Hello everyone,
I hope you are well.
I want to create a service that changes the value of a property. This service takes in an input (true or false) which is then assigned to the property's value.
I want to use the button to accomplish this. Meaning only when I click the button will I get either a true or false value. This will cause the property to change value whenever the button is clicked.
The problem is buttons do not take in state definitions (Where I planned to keep the true/false).
How else can I accomplish this?
Your suggestions will be much appreciated.
jensc
(To:Janicen)
You could use an expression to set your buttons custom css class dependent on your boolean value.
So maybe something like this:
if (true) {
 result = myButtonClass1
} else {
 result = myButtonClass2
Put these in the Custom CSS tab
and then bind the custom CSS input on your button to the result of your expression.
.myButtonClass1 .widget-ptcsbutton {
    background-color: red !important;
.myButtonClass2 .widget-ptcsbutton {
    background-color: green!important;
Hope this helps.
2 REPLIES 2
I managed to do this using a service.
In my service, I used a conditional statement to check the current value of the property and then assigned the property a new value.
Now I am looking to change the color of the button depending on the property value (either true or false).
Is it possible to do this using an expression?
Best Regards.
jensc
(To:Janicen)
if (true) {
} else {
Hope this helps.
