Hi ,
---Nested InfoTable
I need to display multiple tables in the mashup with ONE server call . So I created a data shape and add the fields with data type "InfoTable". In the mashup , I bind the field to advanced grid instead of "all data", so I call it nested InfoTable.
---Dynamic columns
I also need the columns of the advanced grid to be dynamic , so I don't set data shape for the InfoTable fields . Only advanced grid supports dynamic columns , grid doesn't support it.
But advanced grid does NOT work in the combination of Nested InfoTable + Dynamic columns. It just display the data as Empty lines. See the summary table and attached image below:
Is it a known issue ?
Dynamic Column | Nest Table | ||||
Yes | No | Yes | No | ||
Dynamic Column | Yes | / | / | Doesn't Work | Works Well |
No | / | / | Works Well | Works Well | |
Nest Table | Yes | Doesn't Work | Works Well | / | / |
No | Works Well | Works Well | / | / |
Sean
The workaound is to avoid to use the nest table as the server's result in the mash , instead , use multiple services.
Hi @seanccc.
Can you provide some of the entities from your example so we can take a closer look at what you're trying to do? What version of ThingWorx are you running?
--Sharon
Hi @seanccc.
Please let us know if you're still experiencing an issue. If you have found a solution, please feel free to post it here and mark it as the Accepted Solution for the benefit of others on the community.
--Sharon
I still have the issue but also found out a workaround for it. I'll create a reproducible file later.
Hi @seanccc.
Just checking to see if you could share the workaround you found. It would be helpful for others in the community with the same issue.
--Sharon
