Is there a document on the AlwaysOn protocol somewhere?
I need the AlwaysOn web sockets info to send data from edge device to Thingworx.
Due to intellectual property, the protocol does not get distributed. If you are a partner/have an appropriate license, please contact your sales representative to further discuss this.
Not what I need.
I want to write my own code that uses web sockets to communicate with Thingworx server using the AlwaysOn protocol.
I can't use the SDKs or install WS EMS on a linux machine. So I need to know the actual AlwaysOn protocol... not a C library I can only link to.
The document must exist internally somewhere.
Any luck? I am considering reimplementation to nodered in JS.
