I have one problem about analytics dataset, when I click the data and it shows the error message as below.
Error invoking service: Unable to Invoke Service GetDatasetsWithStats on TW_ML_Helper : Execution error in service script [TW_ML_Helper GetDatasetStatus] : Wrapped java.lang.Exception: Invalid Global Session Parameter [optimizeErrorCount] Cause: Invalid Global Session Parameter [optimizeErrorCount]
I tried to fix it, but there is few information about this. Thank you for assistance!
Matt
Hi Matt
You may want to check this article: https://www.ptc.com/en/support/article?n=CS250253
and ensure you have completed all the configuration steps detailed in the Help Center.
Kind regards
Christophe
Hi Matt
Kind regards
Christophe
Hello Christophe,
I am working with Matt and this fixed the problem for us.
Thanks a bunch!
Tyler
Hi Christophe,
It works for your instruction. That's very helpful, and I very appreciate it!
Matt
