Hello Community,
I just finished federating data from one TWX instance to another.
On the new instance I keep getting this error in the application log:
<< Error [authenticating connection], Server websocket will be closed. cause: Missing application key!. >>
This error appears every millisecond.
I tried to stop and start Thingworx by using a tomact start and stop, this restarted the server but did not eliminate the error. I am TWX version 9.3.8
Any ideas on how to tackle the problem.
TB
Hi @Janicen.
From a review of the case it appears your issue was the result of a local install of Kepware trying to make a connection to your ThingWorx server. Reconfiguring your Kepware instance should have resolved the issue.
Regards.
--Sharon
Hi @Velkumar
Thank you,
The second article address my issue. However, I am unsure of how to
I went to my server files and opened the server.xml. However I couldn't seem to locate the "tomact port" number inside of this file, Perhaps is it called something different inside of the file?
Please refer to this post - How to change Apache Tomcat web server port number - Stack Overflow
My suggestion would be to open a support ticket with PTC for this issue.
/VR
Hi @Velkumar
The tomcat port is correct. Thanks for that. However the issue persists.
I checked and it seems that there is a EP_889 Thing that is bound to the Thingworx server template.
However the EP_889 thing cannot be found. Can you if possible elaborate on the Thingworx server template. When and why it is used?
Meanwhile, I will open a support to get the issue resolved.
TB
Hi @Janicen.
Regards.
--Sharon
Hi @Janicen.
This is not a port issue. It's more likely that the first article provided by Velkumar contains the most likely solution based on the information you provided.
I found that you have opened a case for this issue, so once the solution is found, I will post an update here.
Regards.
--Sharon
