AppKey error: Rejecting NonceKey
  • May 29, 2023
  • 2905 views
Hello Community,
I just finished federating data from one TWX instance to another.
On the new instance I keep getting this error in the application log:
 << Error [authenticating connection], Server websocket will be closed. cause: Missing application key!. >>
This error appears every millisecond.
I tried to stop and start Thingworx by using a tomact start and stop, this restarted the server but did not eliminate the error. I am TWX version 9.3.8
Any ideas on how to tackle the problem.
TB
Best answer by slangley
Hi @Janicen.
From a review of the case it appears your issue was the result of a local install of Kepware trying to make a connection to your ThingWorx server.  Reconfiguring your Kepware instance should have resolved the issue.
--Sharon
Janicen16-PearlAuthor
Hi @Velkumar
Thank you,
The second article address my issue. However, I am unsure of how to
  • Change the Tomcat port in Server.xml resolved the issue
I went to my server files and opened the server.xml. However I couldn't seem to locate the "tomact port" number inside of this file, Perhaps is it called something different inside of the file?
@Janicen
Please refer to this post - How to change Apache Tomcat web server port number - Stack Overflow
My suggestion would be to open a support ticket with PTC for this issue.
/VR
