Hi all,
I want to get rid of manual import/export from dev to qa/pro. Is there any way by which I can complete these kind of migration automatically?
Thank you!!
HI,
You can use a scheduler to execute the functionality of export which is part of entity service I believe, if two server are on same network, in URL you can mention the path where to set the export file.
Regards
Shyam
Hello Shyam,
Thank you for your response. Using scheduler will not help me, as I am not importing the entities at fixed interval.
Thank you!!
Then just need rest services to call export functionality. Thats it.
Hi @MM_9023322.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
