Azure IoT Hub data streaming to Thingworx composer
kishu
Hi PTC,
I have established the connection between azure IOT hub and thingworx composer. I want to stream the data coming to IotDevices in IoThub to thingworx -> thing -> property. And also i want to parse the data (data format-> {"Temperature":24,"humidity":50}) to two different thing properties like 'temp' and 'hum'.
PaiChung
22-Sapphire I
(To:kishu)
kishu
(To:PaiChung)
I have done all this... after importing IoT devices from azure IoT hub... i want to read the data coming to them in thingworx studio.
I have acheived till here...
http://support.ptc.com/help/thingworx_hc/thingworx_cx_services/#page/thingworx_cx_services%2Fazure_connector%2Fc_azure_connector_deploy_in_azure.html%23
PaiChung
22-Sapphire I
(To:kishu)
You are at the hub configuration part? that should just be configuration with then after that importing the proper extensions and setting up an AzureIoT Thing within Thingworx
After that when you have the values coming into Thingworx, then next you would create a Service that exposes the necessary information and then bring that into Studio.
