The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
Hi PTC,
I have established the connection between azure IOT hub and thingworx composer. I want to stream the data coming to IotDevices in IoThub to thingworx -> thing -> property. And also i want to parse the data (data format-> {"Temperature":24,"humidity":50}) to two different thing properties like 'temp' and 'hum'.
I have done all this... after importing IoT devices from azure IoT hub... i want to read the data coming to them in thingworx studio.
I have acheived till here...
You are at the hub configuration part? that should just be configuration with then after that importing the proper extensions and setting up an AzureIoT Thing within Thingworx
After that when you have the values coming into Thingworx, then next you would create a Service that exposes the necessary information and then bring that into Studio.
