Bar Graph - Reference Line
LP_10027711
According to this https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Mashup_Builder/Widgets/AddingReferenceLinesToAChart.html# I can add a reference line to a Bar Chart. I do not see this property on my bar graph widget:
1 ACCEPTED SOLUTION
slangley
23-Emerald II
(To:LP_10027711)
Hi @LP_10027711.
Yes, reference lines were added in 9.2--see the 9.2 What's New page.  Backporting an extension isn't supported.
--Sharon
12 REPLIES 12
slangley
23-Emerald II
(To:LP_10027711)
Hi @LP_10027711.
You first have to indicate the number of reference lines in the NumberofReferenceLines property--it defaults to 0.  Then the reference line properties will appear.
--Sharon
LP_10027711
(To:slangley)
I have Thingworx v 9.1, according to this i need v 9.2. please confirm that is the case? if so, is there a way to just update the widget extension?
slangley
23-Emerald II
(To:LP_10027711)
Hi @LP_10027711.
--Sharon
LP_10027711
(To:slangley)
thank you! is it an update upgrade to go from 9.1. to 9.2? what documentation can i use?
slangley
23-Emerald II
(To:LP_10027711)
Hi @LP_10027711.
If you're considering an upgrade, I recommend moving to the latest release of 9.3.1.  The documentation for upgrading can be found here:
System Requirements 9.3
Installer Upgrade
When performing an upgrade, best practices dictate the following steps occur prior to upgrade to ensure recovery if issues occur:
  • Shut down ThingWorx
  • Create a snapshot of the app server
  • Create a db export
  • Restart ThingWorx
  • Update a non-prod environment prior to upgrading prod.  If possible refresh the non-prod environment with prod data
  • Perform a regression test following the non-prod upgrade to identify any changes needed as a result of the upgrade
  • Document all steps and determine timings
--Sharon
LP_10027711
(To:slangley)
thank you
LP_10027711
(To:slangley)
Hi sharon. i am going to run through the upgrade from 9.1 to 9.3 today. wish me luck! thanks for the info
slangley
23-Emerald II
(To:LP_10027711)
Good luck!
--Sharon
LP_10027711
(To:slangley)
i failed completely! I had to revert to v9.1
slangley
23-Emerald II
(To:LP_10027711)
Hi @LP_10027711.
What errors did you receive?  Do you still have the failure logs that I can take a look at?  Refer to this page for locating the logs.
--Sharon
LP_10027711
(To:slangley)
i created a post for it and no one replied so I did not get it upgraded.
https://community.ptc.com/t5/ThingWorx-Developers/Thingworx-upgrade-9-1-to-9-3-error/m-p/787112#M57479
slangley
23-Emerald II
(To:slangley)
Hi @LP_10027711.
Thanks for responding.  I will follow up on the other post,
--Sharon
