Binding output from multiple service to single widget?
SOLVED
How can we bind output from two different services to single widget?
eg: two different output to single grid?
V Shalini
1 ACCEPTED SOLUTION
Re: Binding output from multiple service to single widget?
Hi @svisveswaraiya-,
As far as I am aware it is not possible for widgets to accept more than one input. What you can do though is write a service that combines the output of two or more services in the specific format the widget understands it.
Specifically to "infotable" type outputs, I find a couple of the Snippets under the "InfotableFunctions" like Union very handy, or merely creating a new infotable and adding fields and rows to that as required.
I hope it helps a bit.
Kind regards,
Johan Bester
2 REPLIES 2
Kind regards,
Johan Bester
Highlighted
Hi @svisveswaraiya-
If the response provided by Johan answered your question, please mark it as the Accepted Solution for the benefit of others who may have the same question.
--Sharon
