How can we bind output from two different services to single widget?
eg: two different output to single grid?
V Shalini
Hi @svisveswaraiya,
As far as I am aware it is not possible for widgets to accept more than one input. What you can do though is write a service that combines the output of two or more services in the specific format the widget understands it.
Specifically to "infotable" type outputs, I find a couple of the Snippets under the "InfotableFunctions" like Union very handy, or merely creating a new infotable and adding fields and rows to that as required.
I hope it helps a bit.
Kind regards,
Johan Bester
Hi @svisveswaraiya,
Kind regards,
Johan Bester
If the response provided by Johan answered your question, please mark it as the Accepted Solution for the benefit of others who may have the same question.
Regards.
--Sharon
