We are working to address an issue with subscription email notifications. In the meantime, be sure to check your favorite boards for new topics.
C-SDK - unable to file transfer from Thingworx to the Edge Device
ysb
6-Contributor
6-Contributor
I'm running the c-sdk 2-2-3-1545  in a device and when I try to download a file from the Thingworx repository to the device, by using twFileManager_GetFile(), I receive the following error:
[ERROR] 2019-12-03 15:09:59,666: twMessaging::handleMessage: Response ID 20 has code 160: Entity FileTransferSubsystem does not exist or is not yet associated with a Thing
[ERROR] 2019-12-03 15:09:59,666: twFileManager_TransferFile: Error invoking Copy service on FileTransferSubsystem
I tried to call the Subsystems["FileTransferSubsystem"].Copy() service (In the Thingworx side) to validate the parameters that I was using, and everything worked fine.
Can anybody help me with that ?
Did you faced that error before?
Thanks in advance.
smainente
(To:ysb)
1. What is the error on the platform side ?
2. When you tested the Subsystems["FileTransferSubsystem"].Copy()  service, did you use the same user as the CSDK agent ? "Entity ...does not exist"  is generally a permission issue.
ysb
6-Contributor
6-Contributor
(To:smainente)
Hi @smainente ,
Thanks for the fast reply.
1- I'm just facing errors in the device side. When I run Subsystems["FileTransferSubsystem"].Copy() I don't face any error in the platform side.
2- No, I was using different users. I will check that.
Thank you.
ysb
6-Contributor
6-Contributor
(To:smainente)
Hi @smainente ,
1 - These are the errors in the Platform side :
-Unable to dispatch [ uri = /Subsystems/FileTransferSubsystem/Services/Copy/]: Unable to Invoke Service Copy on FileTransferSubsystem : Thing <thingworx hostname > Does Not Exist
-error executing APIRequest Message: Unable to dispatch [ uri = /Subsystems/FileTransferSubsystem/Services/Copy/]: Unable to Invoke Service Copy on FileTransferSubsystem : Thing <thingworx hostname> Does Not Exist, sending ERROR ResponseMessage to caller!
2- I tested with the same user this time....
