I have a CSV file and I have simple request which is to upload this CSV file to thingworx. When I try uploading from data, it didn't work. When I try to upload from Import option, it didn't work. I don't want to upload data with parsing. I want to upload whole data at a time. Is it possible?
My data is clean, there is no problem, but I cannot upload data. By the way I'm workin on PTC Cloud, because desktop version for ubuntu cannot be installed any way.
Thanks.
You need to use CSV Parser extension. Please check this article: https://www.ptc.com/en/support/article/CS294337
Hope it helps,
Raluca Edu
Hope it helps,
Raluca Edu
Hi @Beyza
Could you clarify what is the intent of your csv file ?
Do you want to use it as a dataset in ThingWorx Analytics ?
Christophe
Hi @Beyza.
If the previous response from Raluca answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
