CSV File Import
Beyza
3-Visitor
CSV File Import
I have a CSV file and I have simple request which is to upload this CSV file to thingworx. When I try uploading from data, it didn't work. When I try to upload from Import option, it didn't work. I don't want to upload data with parsing. I want to upload whole data at a time. Is it possible?
My data is clean, there is no problem, but I cannot upload data. By the way I'm workin on PTC Cloud, because desktop version for ubuntu cannot be installed any way.
Thanks.
raluca_edu
(To:Beyza)
You need to use CSV Parser extension. Please check this article: https://www.ptc.com/en/support/article/CS294337
Hope it helps,
Raluca Edu
raluca_edu
(To:Beyza)
Hope it helps,
Raluca Edu
cmorfin
(To:Beyza)
Hi @Beyza
Could you clarify what is the intent of your csv file ?
Do you want to use it as a dataset in ThingWorx Analytics ?
Christophe
slangley
(To:Beyza)
Hi @Beyza.
If the previous response from Raluca answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
