Calculating how many times a property value repeats in QueryPropertyHistory Service
Aditya1702
I have logged property into a value stream and using QueryPropertyHistory service I am able to have a view at the recorded data of the logged properties. What next I wan to achieve is how can we calculate the number of times a value of a property repeats in the data recorded, upto a particular date.
eg, I have property called stepValueStatus which has a string value pass/fail. So I want to calculate how many times pass occurs and how many times fail occurs for this stepValueStatus property.
Thanks in Advance.
Aditya Gupta
Hi @Aditya1702
Set your service Output as InfoTable and set DataShape to it.
In Mashup, Call this service and map output to Grid Widget.
/VR
8 REPLIES 8
Hi @Aditya1702
You can use the Aggregate Function to get a count of values
let params = {
    t: me.dummyInfoTable/* INFOTABLE */,
    columns: "name" /* STRING */,
    aggregates: "COUNT" /* STRING */,
    groupByColumns: "name" /* STRING */
// result: INFOTABLE
let result = Resources["InfoTableFunctions"].Aggregate(params);
Input:
Output :
/VR
Aditya1702
(To:Velkumar)
Hi @Velkumar ,
What to add in place of dummyInfotable since I don't have any infotable I get infotable as an output of QueryPropertyHistory Service.
Can you please elaborate a bit more since, I am new to ThingWorx.
Thanks in Advance.
Aditya Gupta
Hi @Aditya1702
Replace me.dummyInfoTable with an output of QueryPropertyHistory service
var data = me.QueryPropertyHistory({
    maxItems: undefined /* NUMBER {"defaultValue":500} */,
    startDate: undefined /* DATETIME */,
    endDate: undefined /* DATETIME */,
    oldestFirst: undefined /* BOOLEAN */,
    fillOption: undefined /* STRING {"defaultValue":"Previous"} */,
    query: undefined /* QUERY */
let params = {
    t: data /* INFOTABLE */,
    columns: "FIELDNAME_TO_COUNT" /* STRING */,
    groupByColumns: "FIELDNAME_TO_COUNT" /* STRING */
/VR
Aditya1702
(To:Velkumar)
Hi @Velkumar ,
Thank you it did worked!!!
One more thing what if I want to display these counts (T1 as 3, T2 as 2 & T3 as 1) in mashup how can I go about this?
Hi @Aditya1702
/VR
Aditya1702
(To:Velkumar)
Hi @Velkumar ,
Thanks a lot for your quick help.
Thanks & Best Regards,
Aditya Gupta
Aditya1702
(To:Velkumar)
Hi @Velkumar ,
Good Evening,
I am facing problem in logging properties there are some values which are repeating after I carry out the experience third time.
PFA attached image in which arrows are shown on the readings which are repeating when I consume the AR experience on my Ipad on view app the third time.
Thanks in Advance.
Aditya1702
(To:Aditya1702)
The repetition of the values is random.
Can anyone help me out with this?
Thanks in Advance.
