The TwxRuntimeKey is not deleting and its still there for older days. someone help me to resolve this issue.
Bharathan
Which version are you on? This might have been fixed in a current minor upgrade.
I think this happens when the system is restarted before the appkey up for removal.
As a workaround, you can delete them by using DeleteApplicationKeys service from UserManagementSubsystem. Set deleteExpiredKeys as true and deleteUnExpiredKeys as false
