Can I change the modal pop up location by css
SK_9989757
6-Contributor
I want to check if the modal popup location, that is center of the screen can be changed by any means?
We do this using custom CSS on mashup level where navigation function is used.
Steps to reproduce:
  1. Define navigation function as ModalPopup
  2. View mashup and execute navigation
  3. Use devtools to inspect the html and find the id of the modal popup div
  4. Define the required position in the mashup custom CSS section (We also change the background blur opacity in this example):
.mashup-popup[id$='-2_navigationfunction-54-popup'] {
	left: 6px !important;
	top: 106px !important;
	position: absolute !important;
.mashup-popup[id$='-2_navigationfunction-54-popup'] .widget-bounding-box[id$='-2_navigationfunction-54-popup-bounding-box'] {
	width: auto !important;
	height: auto !important;
.mashup-popup-overlay {
	opacity: 0.25 !important;
Hope this helps.
3 REPLIES 3
Hi @SK_9989757  Look at the below issue, looks similar to your issue, let us know if it does not match your use-case.
https://community.ptc.com/t5/ThingWorx-Developers/Border-Radius-to-Modal-Pop-ups/m-p/778073#M56806
Steps to reproduce:
Hope this helps.
Much appreciated, really nice example!
