Can someone help with User permissions in Thingworx
SY_10165961
6-Contributor
I have created a new mashup with my admin account and than created a different user groups.
I have provided run time permission to the user group but when i login from any user of user group i am not able to view the mashup it shows blank.
Can you please help me what could be checked in such scenarios?
Hello @SY_10165961
Could you pls verify if it is working for the Administrator?
If yes, then also check that your users have visibility Media, Style definitions, State definitions, Themes, etc. --
all that you have utilized in your design.
Thenafter, You can troubleshoot it by pressing F12 in your browser and Open the Network tab for errors in HTTP requests.
If there's a Issue with permissions, you can observe some red lines there, click on them and look at the Response,
it should explain what exactly is the issue.
Another thing that you may check Application.log and Security.log. You can get some hints there what is not visible for users or what objects need permissions. You can Check the given tutorial in case you need more info on permissions in ThingWorx: https://developer.thingworx.com/en/resources/guides/data-model-security-control
Let me know if you need anything further.
Bhawna
Hello @SY_10165961
Bhawna
