Can't display data in mashup when I change thingworx server Ip
csun-21
3-Newcomer
Can't display data in mashup when I change thingworx server Ip,I add a new grid it display. I don't know why? Please help me, thanks
8 REPLIES 8
ankigupta
(To:csun-21)
Hi cyril sun​,
Did you restart the tomcat too after the Ip change?
csun-21
3-Newcomer
(To:ankigupta)
Thingworx Server was installed in vmware,I have restart it.
AnnaAn
(To:csun-21)
Hi Sun,
Did you install PostgreSQL version of Tomcat? Did you install PostgreSQL on different server? and if so please try to change the platform-settings.json file accordingly after the ip change, and restart Tomcat again as Ankit suggested.
Br,
Anna
supandey
(To:csun-21)
Cyril, how are you getting the data is this from a local DataTable Thing or is it from an external database?
csun-21
3-Newcomer
(To:supandey)
hi,from an external database(mysql)
supandey
(To:csun-21)
Is the connectivity working fine for the existing service connecting to the external database? Could you also share the application log when you try to view the "old" grid data
csun-21
3-Newcomer
(To:csun-21)
Maybe I use a template(the template extends MysqlServer template) to config the database infomation.I modify the each thing to use msqlServer Template,then it's ok.
supandey
(To:csun-21)
Agree with you cyril sun​ I think with that it will be easier for you to manage the configurational changes
