Currently, I have a datatable with 1 primary key.
The datatable has data in it. The datatable has around 100 records.
I want to add another primary key so that I achieve composite key on the datatable.
Can this be done?
Anirudha
You can do it for sure, but existing entries will have wrong internal "key" content, what I would do it's recreating existing entries.
Ok
