Can we customize the field names while hovering bars in barchart without changing datashape?
AP_10343008
On hovering over bars in barchart, it is showing the field name provided in datashape.  Can we customize the field names while hovering over bars in barchart without changing its field names in datashape?
Hi @AP_10343008 ,
Hope this attached article helps you Customizing the Chart Legend .
Step 1 : Set 'NumberOfSeries' in chart properties.
Step 2: Provide customized value for 'DataLabelN' to shoe legend in series & hover on bar.
Expected Out:
Thanks & Regards,
Arun C
I couldnt see the propert which is showing for you. Iam using thingworx 9.1 version.
Hi @AP_10343008 ,
This DataLabel1 — DataLabel24 will available later TWX 9.1.2 version .
Thanks & Regards,
Arun C
Then I cant find it in my current thingworx server version. Thanks for the solution
