Can we list Thingworx entities which are created by a specific user in Thingworx ?
koushal
Hi All,
I just want to list out those entities which are created by a a specific user. Is we have something in Thingworx?
wposner-2
(To:koushal)
If you have direct access to the TWX DB you could create a secondary JDBC connection to it and then write a query on your new DB thing that looks in the public.thing_model table to get you this information.
There is no out of the box service for that.
I don't know if it helps, but you can see owner if you export entities in xml format.
Raluca Edu
wposner-2
(To:koushal)
slangley
(To:koushal)
Hi @koushal.
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
If wan't be super speedy, but you can do as follow:
var result = Resources["SearchFunctions"].SearchAll().thingResults;
result.AddField({name: "owner", baseType: "STRING" });
var creator
for each(row in result.rows) {
    try {
        creator =  eval(row.parentName)[row.name].GetConfigurationChangeHistory().Find({ changeAction: "CREATE" });
        if (creator!==null) {
            row.owner = creator.user;
    } catch(error) {}
Sorry, this is to get all entities owner, you just need to filter by the desired user and you are done.
