Hello everyone,
Our ThingWorx configured with SSO configuration using CAS(PingFederate). Now, I would like to login with other user, Can we login ?
Could please anyone send the possibilities to login?
madhu
Hi @mnalla,
in Active Directory 'Administrator' account is the reserved account for AD Admin. if you have the password for that user from AD, you can log in with Administrator account. However suggestion is to create a new user who has all Administrator rights and use it as Admin when PingFed SSO is configured.
BR,
Harsh
As far as i know once you have a session, SSO will send a token.
1. You can use an anonymous or private window and log in with another sso user
2. To bypass SSO and login with a non sso user would only be possible, by utilizing an appkey
Hi PaiChung,
As per my understanding, We should a create a non sso user with App Key.
after how should i login into the instance. Could you provide any document or can you guide me the steps to accomplish it.
Thanks.
Cheers,
madhu
Hi @mnalla,
If you have configured PingFederate SSO with ADFS, all the users will be fetched from ADFS only. You won't be able to use any other default authenticator.
BR,
Harsh Selarka
Hi Selarka,
I am able login with other user who are in SSO Configured ADFS. Would it be possible to login with Administrator?
thankYou,
madhu
Hi @mnalla,
BR,
Harsh
Hi @mnalla,
Did the responses provided helped you with the question you had? If yes, please select the 'Accept as Solution' to close this thread. If these didn't helped you and if you have any further questions, please post it.
BR,
Harsh
