I want to use angular 8 for making my widgets, how to do that ?
There is an existing post regarding creating widgets in Angular, I presume you are already aware of this and you're asking specifically for Angular version 8?
Yes, That process is cumbersome and it uses Angular JS which I am not comfortable. Actually I have made a drag and drop feature in Angular 8 and want to deploy it in TWX, can you help?
