I'm trying to import 'Gantt Chart Widget' extension and I get the following error:
Any help is appreciated.
Thanks!
What is your ThingWorx version?
If it's one of the newer patches, you may need to enable all of the extension import policies in your platform-settings file (see helpcenter for extensions import).
Also please note the extension is no longer supported and provided in as-is condition
https://marketplace.ptc.com/apps/200303/gantt-chart-widget#!overview
Hi posipova
I did check the link and realized that's my 8.4 Thingworx is not supported
Anyway, thank for your support.
