Hi Community,
I`m running out of ideas when trying to connect my OPC UA server to the Thingworx platform..
That`s where I`m at and what I tried:
1. Connect to the Server with UA Expert or Prosys OPC Client >> works fine.
2. Use the OPC Client extension to connect to the Thingworx Platform:
I suspect that I need to configure something in Thinworx to establish the connection, but I do not know what that could be.. I also could not connect the Prosys Simulation Server which undermines that point.
Would it be possible to use Kepware in Thingworx with a non-Kepware OPC UA server? I tried that but also did not succeed.
Are there any other options besides OPC UA client extension and Kepware?
Thanks a lot for whatever advice!
You could connect to a non-Kepware OPC UA server(OPC UA server that is not included in Kepware package) via OPC UA Client driver in Kepware. Please follow the documentation attached for more details.
ps. it happens that in the documentation it takes the example that both client and server are included in Kepware package, but it's not saying that OPC UA server should be included in Kepware package, it could be other kind of 3rd party OPC UA server.
As your question "Would it be possible to use Kepware in Thingworx with a non-Kepware OPC UA server? "
Yes you could connect to other kind of OPC UA server that is not included in Kepware package. In Kepware just use the OPC UA client to connect to a 3rd party OPC UA server and you could follow this documentation to configure both parts(it happens that both of the client and server are included in Kepware Package in the example in the documentation, but it's not saying it's only supporting OPC UA Server in Kepware package):
Hi AnnaAn,
Thanks for the reply!
I`ve now used KEPServerEX 6 Configuration, to connect with my Server and the Thingworx Server. I`m now able to see the parameters in the KEPServerEX application. (Picture) How can i now bind them to the properties in Thingworx?
Is this the right approach? If I understand correctly, the KEPServer 6 on my PC is collecting the data from my other OPC UA server and then streams it to Thingworx.. Would this also be possible directly and not via my PC?
Thanks!
Regarding your question "Is this the right approach? If I understand correctly, the KEPServer 6 on my PC is collecting the data from my other OPC UA server and then streams it to Thingworx.. Would this also be possible directly and not via my PC?"
Yes that's correct approach to get OPC UA server data. If you install Kepware on another machine(say, same server to the OPC UA server, but it's not commanded) you will not need your PC to send data via your PC. The idea is that we use the kepware as a gateway to read data from OPC UA server and then as a OPC Server it sends data to the clients(say, ThingWorx)
That's a good start you have connected to OPC UA server via Kepware. Next step you would follow
this KCS Article to know how to push Tag value to ThingWorx platform.
Thanks for the clear explanation, makes sense now.
Could you please link the article you were referring to again? The Hyperlink sends me to the current topic
Thank you!
