Change Base Thing Template
dkeeley
7-Bedrock
Is there a way to change the base thing template on a thing or thing template? We want to do this as a one-off activity on a thing template.
David.
Hi David,
This is the unofficial way   https://community.thingworx.com/message/47788#47788
Best Regards,
Carles.
supandey
(To:dkeeley)
Hi David,
As per my knowledge this is not possible once the thing is created and saved, best option would be to delete it and recreate the Thing. Do you have depending data from that thing being logged in a Stream/Value Stream?
Hi David,
Best Regards,
Carles.
