Change property value from service (javascript)
binaryPUNCH
Hi. Can I please see a simple example on how to change the value of a property from a javascript service? A property on the same thing the service is running on. I'm struggling a little on figuring this out and finding the proper documentation.
I can get the property object through the Things["TestThing"].GetPropertyDefinition() function but what then? How do I know the name of the thing that invoked the service? Must it be an input parameter :(
2 REPLIES 2
A service is called from a Thing, so if you want to change the value of a property just use:
var my_value="test";
me.property_name=my_value;
Instead of me, you can use the name of any Thing you want.
Best regards,
Raluca Edu
@binaryPUNCH
Have you found a solution to your problem?  If so, please indicate the appropriate response as the Accepted Solution for the benefit of other Community members who have the same question.
-Vibhuti
