Hi Team,
Suppose I have a below network hierarchy:-
A1(Type Apple)
B1(Type Banana)
C1(Type Cheeku)
C11(Type Cheeku)
A2(Type Apple)
B2(Type Banana)
C2(Type Cheeku)
And I select node C1, then I want to change the font style of all its parents only i.e. B1 and A1 to 'Bold' and don't want to touch the styles of A2 and B2 nodes (as C1 don't belong to that sub-hierarchy).
What I used the approach of making all three fruit type style definitions from Composer and then updating those via script as bold, it created one issue that it updates all the Apple and Banana Type nodes (like A2 and B2) as all are having same style definition using state definition rules (rule is on Fruit Type).
Could somebody help me with the logic of how to update parent node styles only in particular sub-hierarchy and not in the entire network hierarchy. (on selection of every node)
Thanks in advance.
The ThingWorx version is 9.1.
Actually, I don't have any idea about how to use Custom CSS in thingworx that's why haven't expored that way.
Could you please send me the logic of your approach if you have completely understood my use-case.
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
