How to Retrieve infotable data row selected from aggregate function
  • January 21, 2021
  • 1690 views
Hello, I am looking to get the minimum column value from an infotable using the aggregates function. The issue is that the aggregates result, it only retrieve the min value.
I want to know how retrieve the entire row of the infotable that the aggregates selected as a result. ¿Is that possible?
This is my code:
var params = {
t: infoTable /* INFOTABLE */,
columns: "RD_MP_PRED" /* STRING */,
aggregates: "MIN" /* STRING */,
groupByColumns: undefined /* STRING */
result = Resources["InfoTableFunctions"].Aggregate(params );
The result variable is a number.
Community Manager
January 22, 2021
Hi @AliceHdzR.
One option would be to pass the result back in to retrieve the rows matching that value via find and filter functions.  For your scenario, the EQFilter sounds like the best choice.  The EQFilter is a service available in the Infotable Functions resource.
Regards.
--Sharon
AliceHdzR1-VisitorAuthor
Hi @slangley ,
thank you for your response, I don´t really wanted to do that but I guess I will have to use that strategy as a solution because I cannot find another way for retrieve more information of the selected aggregates function result, it only gives me the minimum value.
Here is my code, I hope this could help someone else:
//First I get the minimum value groupByColumns ORDEN (I used this name as an ID) because dataVerdes has several duplicated rows, so I have to apply the group by.
var MINVerde = Resources["InfoTableFunctions"].Aggregate({
t: dataVerdes /* INFOTABLE */,
groupByColumns: "ORDEN" /* STRING */
//The result of MINVerde is a 2 column and 3 different rows infotable with their minimum value and the ORDEN value
//Then I get the minimum of MINVerde but with groupByColumns as undefined, so I can get only 1 result
var MINVerde2 = Resources["InfoTableFunctions"].Aggregate({
t: MINVerde /* INFOTABLE */,
columns: "MIN_RD_MP_PRED" /* STRING */,
//This is the solution suggested, I generate the EqFilter, so I can compare the result of MINVerde2 vs MINVerde result (that has 2 columns and 3 rows)
var vMinRpMpPred = MINVerde2.rows[0].MIN_MIN_RD_MP_PRED;
var queryMinVal = {
"filters": {
"fieldName": "MIN_RD_MP_PRED",
"type": "EQ",
"value": vMinRpMpPred
var dataMinVerde = Resources['InfoTableFunctions'].Query(
query : queryMinVal,
t : MINVerde
result = dataMinVerde;
//And finally the result is an infotable with the information of the MINVerde that contains also the column ORDEN, not only the minimum value.
Community Manager
January 22, 2021
Hi @AliceHdzR.
Someone else in the developer community may have a better idea, but at least you have a workaround for now.
Regards.
--Sharon
