Clear the radio button option
Shrikant
3-Newcomer
How can I clear the radio button selection by clicking on the currently selected option in radio button ?
Please check the attached image file for reference
3 REPLIES 3
Hi @Shrikant ...
I don't think it's possible. I couldn't empty it with the on-board methods and services.
I've also tried using an Expression Widget to overwrite the state and set an Output forces a non-selected state for the Radio Button Widget - but haven't really figured it out yet.
I'd say it's a limitation to the Widget, that once it's set it can't be unset.
Depending on the use case you could add an additional state (selected by default) e.g. "No Selection" - and if this is selected, it will not change / trigger dependent actions...
Seems like there already exists an enhancement for introducing this functionality.
https://www.ptc.com/en/support/article?n=CS260155
I'll add a reference to this thread to the request as well...
Shrikant
3-Newcomer
(To:mneumann)
Ok Thanks
