I have used collection widget and mapped info table to collection widget Data. I have mentioned the name of mashup in mashup field. I cannot see the mashup parameter in properties. How can i map info table fields to mashup parameter. As in repeater widget it shows all fields in properties. How can i achieve that using collection widget.
MashupPropertyBinding:{"id":"Projectid","Name":"ProjectName"}.
MashupGlobalPropertyBinding:{"Projectid":"String", "ProjectName":"String"}.
You should write your Collection Mapping like this:
Hi @isha.
Can you provide a screenshot of MashupGlobalPropertyBinding:{"Projectid":"String", "ProjectName":"String"}?
Also click the configure bindings button for collection-7 from your screenshot, and send us a screenshot of the new window that opens:
--Sharon
Hi @isha.
If one of the previous responses allowed you to find a solution to your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
