Collection widget refresh when user zoom in zoom out
luchiian_1902
2-Explorer
I am using collection widget for our mashup page. Inside collection we user navigation to open a pop-up.
If the user will zoom out because is not seeing all the info on laptop screen, the pop-up automatically closed.
What we can do for avoid refreshing collection widget when zoom in zoom out?
Thank you,
Luchiian Alexandru
5 REPLIES 5
Hi @luchiian_1902,
Just for better understanding in your case, Can you please confirm whether the below rounded Option is disabled in your Popup / Modal Popup? Also may i know about your TWX Version?
Thanks & Regards,
Arun C.
It is disabled.
HI @luchiian_1902
Can you please share your Thingworx version which you are facing this issue?
Thanks & Regards,
Arun C
lucky2004alex
(To:Arun_C)
ThingWorx 9.3.3-
Hi @luchiian_1902 & @lucky2004alex ,
I did some work around (Tricky Way) in this same case. May be this suggestion will help you out to solve your problem.
  Kindly the find below given step - wise process :-
  • I have not created the Navigation Link in the Collection - Loader Mashup instead of that I created it in the Main Collection Mashup.
  • With the help Expressions & Event router we can identify the which button (example like - Add/Edit/Delete) clicked recently on Loader Mashup so based on the Collection - MashupGlobalPropertyBinding binding we can find popup name and then navigate to the exact Popup link.
For your reference I have attached the Demo Entities, If possible please import in your development & go through it by viweing the Mashup - CollectionPopupDemo_Main_MU.
In case any queries please ping me here.
Thanks & Regards,
Arun C
