Collection widget selection refreshing while using expandcollapse container in mashup
Velkumar
Hi all,
I have a collection widget with selection enabled. Whenever I expand the side container, the selected row gets refreshed (Refer GIF)
During this event, we are not able to select anything in mashup. Is there any way to solve this issue
TWX Version : 9.0
/VR
slangley
23-Emerald II
(To:Velkumar)
Hi @Velkumar.
Do you have the overlay option selected in the properties panel? You can try selecting that to see if it behaves the way you're expecting.
--Sharon
4 REPLIES 4
Try open a support Case, here: https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
slangley
23-Emerald II
(To:Velkumar)
Hi @Velkumar.
To confirm, you're saying that you can't do anything while the container is expanding, but it works as expected once it has expanded?  How long until it becomes responsive again?
--Sharon
Velkumar
(To:slangley)
It takes 5 - 10 seconds to expand
slangley
23-Emerald II
(To:Velkumar)
Hi @Velkumar.
--Sharon
