Combining specific results from two info tables to another infotables
Chao123
I am needing to combine two Info-tables and display certain information from those on another info-table. I keep getting the error "Error executing service GetSalesOrderPartStyleProduct. Message :: Unable to Execute Union: Field [Customer] was not found in both infotables - See Script Error Log for more details." I understand what it means but cannot figure out where I am going wrong in my code. I created my service which has an info-table output. My thought was switching "Union" to "Join"
var params = {
	infoTableName : "InfoTable",
	dataShapeName : "TrainingDataShape_COB"
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(TrainingDataShape_COB)
var myInfoTable = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
//// result: Two info tables given
var itPartInfo = Things["Training.InfoTable.PartInfo"].GetDataTableEntries(params);
var itOrderInfo = Things["Training.InfoTable.OrderInfo"].GetDataTableEntries(params);
var query = {
    filters: {
        "fieldName":"Color",
        "type": "EQ",
        "value": "Orange"
var params1 = {
	t1: itOrderInfo /* INFOTABLE */,
	t2: itPartInfo /* INFOTABLE */
// result: INFOTABLE
var result = Resources["InfoTableFunctions"].Union(params1)
var orange = Resources["InfoTableFunctions"].Combine({
	t: myInfoTable,
	columns: "OrderLineID",
    	columns: "SalesOrder",
    	columns: "PartID",
    	columns: "Style",
    	columns: "ProductCode",
	count: undefined,
var result = Resources["InfoTableFunctions"].DeriveFields(orange)
Chao123
(To:Chao123)
Well I realize what I did wrong in the above code, a lot things. Now my code will only display as, which is progress but not the result i am looking for:
Here is what I came up with now:
var params = {
var query = {
	filters: {
		type: "AND",
		filters:
			type: "EQ",
			fieldName: "Color",
			value: "Orange"
//Should produce new InfoTable containing desired columns
var params = {
        t1: itPartInfo /* INFOTABLE */,
	t2: itOrderInfo /* INFOTABLE */,
        columns1: 'SalesOrder,OrderLineID,ID' /* STRING */,
	columns2: 'Style,ProductCode' /* STRING */,
	joinColumns1: 'SalesOrder' /* STRING */,
        joinColumns2: 'OrderLineID' /* STRING */,
        joinType: 'INNER' /* STRING */,
var result = Resources["InfoTableFunctions"].Intersect(params);
var result = Resources['InfoTableFunctions'].Query(
		query : query,
		t : myInfoTable
