I am needing to combine two Info-tables and display certain information from those on another info-table. I keep getting the error "Error executing service GetSalesOrderPartStyleProduct. Message :: Unable to Execute Union: Field [Customer] was not found in both infotables - See Script Error Log for more details." I understand what it means but cannot figure out where I am going wrong in my code. I created my service which has an info-table output. My thought was switching "Union" to "Join"
var params = {
infoTableName : "InfoTable",
dataShapeName : "TrainingDataShape_COB"
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(TrainingDataShape_COB)
var myInfoTable = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
//// result: Two info tables given
var itPartInfo = Things["Training.InfoTable.PartInfo"].GetDataTableEntries(params);
var itOrderInfo = Things["Training.InfoTable.OrderInfo"].GetDataTableEntries(params);
var query = {
filters: {
"fieldName":"Color",
"type": "EQ",
"value": "Orange"
var params1 = {
t1: itOrderInfo /* INFOTABLE */,
t2: itPartInfo /* INFOTABLE */
// result: INFOTABLE
var result = Resources["InfoTableFunctions"].Union(params1)
var orange = Resources["InfoTableFunctions"].Combine({
t: myInfoTable,
columns: "OrderLineID",
columns: "SalesOrder",
columns: "PartID",
columns: "Style",
columns: "ProductCode",
count: undefined,
var result = Resources["InfoTableFunctions"].DeriveFields(orange)
Well I realize what I did wrong in the above code, a lot things. Now my code will only display as, which is progress but not the result i am looking for:
Here is what I came up with now:
var params = {
var query = {
filters: {
type: "AND",
filters:
type: "EQ",
fieldName: "Color",
value: "Orange"
//Should produce new InfoTable containing desired columns
var params = {
t1: itPartInfo /* INFOTABLE */,
t2: itOrderInfo /* INFOTABLE */,
columns1: 'SalesOrder,OrderLineID,ID' /* STRING */,
columns2: 'Style,ProductCode' /* STRING */,
joinColumns1: 'SalesOrder' /* STRING */,
joinColumns2: 'OrderLineID' /* STRING */,
joinType: 'INNER' /* STRING */,
var result = Resources["InfoTableFunctions"].Intersect(params);
var result = Resources['InfoTableFunctions'].Query(
query : query,
t : myInfoTable
