Composer Organization visibility permission on custom Style Theme
PG_CG
8-Gravel
During testing of our Application post ThingWorx upgrade from 9.3.8 to 9.6.1 it is found that a custom theme which does not had any visibility permission setting in 9.3.8 was not getting applied to the Mashup in runtime for the non-admin users.
After adding Composer Organization in visibility permission for the style theme, it is getting applied and the UI is rendering properly.
We wanted to know the reason behind this. Is there any change done with respect to permission.
Rocko
(To:PG_CG)
That would be a question to PTC support.
But the behaviour sounds about right to me, so maybe a bug that was fixed?
Rocko
(To:PG_CG)
