Composer loading forever
SOLVED
Re: Composer loading forever
Judging by the logs, the problem is with Kinex as the rest of the system starts up/initializes fine.
Milan Thakker​ could you please provide some inputs on this?
I just reinstalled Thingworx without importing Kinex and still the same issue, I don't think Kinex has anything to do with it??
Could you please provide the new logs?  Also I'm assuming this is Chrome. Does this happen in a different browser too?
Done & yes this is using chrome, also tried IE, both behaving the same.
The only thing I'm seeing in the new logs is this  "Server WebSocket closed unexpectedly and has already been unregistered from Server Endpoint" as if you have edge devices.
Do you have any type of security/ssl setup /firewall that might be the problem when reaching your vm from a local machine?
Yeah, it would seem that this is the case, unfortunately there's nothing i can do about it currently, I created another VM and can connect to the composer fine with that, so it must be a firewall problem.
Thanks for your help anyway!
