Configuration Table Value update
AA_10034462
6-Contributor
I'm storing less frequent data in configuration table, however when i ty to fetch the data using  getConfigurationTableRow service only one value is fetched that too old value. How to fetch latest value from configuration table. Is there any way that updates value of config table instead of adding more data,
Adarsh
PaiChung
22-Sapphire I
(To:AA_10034462)
I would not store 'data' in a configuration table, because that means you are making design changes and it would I believe require a ThingRestart to take effect.
I recommend you use a persistent infotable Property instead.
1 REPLY 1
PaiChung
22-Sapphire I
(To:AA_10034462)
