Connect Manufactuing app with Azure IOT hub
SV_10197221
11-Garnet
We are connecting the edge devices through Thingworx IOT hub connector setup.
Also, we are using Manufacturing apps in our application as a solution.
How do we connect this IOT hub connectors with Manufacturing app, in a similar was as we add the Kepware industrial connection in the control advisor of Manufacturing apps. So that we can add device entities to use the functionality and features of manufacturing app.
PaiChung
22-Sapphire I
(To:SV_10197221)
If you are not using Kepware at the device side, you will not be able to get the discovery and auto create.
You would have to create your own 'discovery' / device creation on the Thingworx platform side.
I don't think I've seen any updates that would allow you to 'discover' and create with edge agent connected devices.
PaiChung
22-Sapphire I
(To:SV_10197221)
