Connect Thingworx on cloud with Kepware on private network
SP_9027038
2-Guest
I'm working on a proof of concept to establish connect remote plc with thingworx that is installed on cloud. To give an overview of current setup we have
PLC and Kepware installed on prem ( in private network ), and
Kepware, and Thingworx installed on a EC2 in AWS in public network.
What is best way to connect both of them? I wish to send data from Kepware ( on prem ) to Thingworx (on cloud) but currently it doesn't work as both are in different networks.
Yes, the guide works when Kepware is run on a computer on a private network network behind a firewall. The computer running Kepware must be able to connect to both the PLC and the server where ThingWorx is running.
Here is a step-by-step guide to connecting Kepware to ThingWorx:
https://developer.thingworx.com/en/resources/learning-paths/using-allen-bradley-plc-thingworx/model-allen-bradley-plc
The guide is one of several guides that cover all the steps in connecting a PLC to ThingWorx
Hi Rick,
Thanks for sharing tutorial. This is definitely helpful. While this guide cover plc thingworx integration, I still have problem when both are in separate network, I looking for way to tunnel out of private network. Can it be done using kepware?
slangley
(To:SP_9027038)
Hi @SP_9027038.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
