I need to connect to a non-Kepware OPC UA server without using the OPC UA Client driver in Kepware, It seem there was an extension called Thingworx_OPC_UA_Client.jar can do this, but I cannot find it in the marketplace anymore .
is there any other solution ?
Sean
Hi Sean,
Why can't you use the OPC aggregator for this use-case? It's available without a license.
https://www.ptc.com/en/support/article/CS279002
The extension you mentioned is old presales content that was not maintained anymore and was removed from the marketplace.
Hi Sean,
