Connect to 3rd party OPC UA Service without using Kepware
seanccc
I need to connect to a non-Kepware OPC UA server without using the OPC UA Client driver in Kepware,  It seem there was an extension called Thingworx_OPC_UA_Client.jar can do this,  but I cannot find it in the marketplace anymore .
is there any other solution  ?
Sean
VladimirRosu
(To:seanccc)
Hi Sean,
Why can't you use the OPC aggregator for this use-case? It's available without a license.
https://www.ptc.com/en/support/article/CS279002
The extension you mentioned is old presales content that was not maintained anymore and was removed from the marketplace.
VladimirRosu
(To:seanccc)
Hi Sean,
