Access Microsoft Access db from Thingworx
Hi All,
I want to fetch some information from Microsoft Access db and display in mashup. I don't see any extension available in Marketplace for this. Is it possible to connect to MS Access through Thingworx. This is very urgent for us. If anyone has already done please help.
Ravi
Hi Ravindra, have you already explored the ADO Service connectivity from ThingWorx? If not you can download the service from PTC Software Download > ThingWorx Edge SDK
Here's quick link to the documentation on ThingWorx Edge ADO Service
Hi Sushant ,
I have tried to thingworx edge service but i am facing following issue :-
Service on start is giving me following error.
Error intializing socket connection.  Err = -1
twWs_Connect: Error restarting socket.  Error 0
I feel this is due to connection string pattern (I have a .mdb file that i need to access)
        "ConnectionType": "OleDb",
        "ConnectionString": "Provider=Provider=SQLNCLI11;Server=localhost;Database=C:\New_folder\NaSCoM\NaSCoM_test.mdb;
Trusted_Connection=yes;",
        "AlwaysConnected": false,
        "QueryEnabled": true,
        "CommandEnabled": false,
        "CommandTimeout": 60
If you can provide with any example it would be great !!
Vipul, have you verified that the connection is not blocked by firewall? could you share the full log from ADO here
Sushant's answer is probably the best way to do this, but I just want to throw out there that there are third party JDBC drivers for MS Access that you could use, if you don't want to run a seperate ADO .Net service (see: UCanAccess-A Pure Java JDBC Driver for Access) These aren't officially supported by Microsoft, but may be a bit simpler to use with TWX; you can leverage the JDBC connector extension to use drivers such as these: https://marketplace.thingworx.com/Items/jdbc-connector-extension.
Hi James ,
I have tried using JDBC driver with ucanaccess. Is this the right way to configure the connection?
Currently it is not showing database as connected.
