I have modified 'AdafruitDHT.py' script from the tutorial to connect AM2302 sensor to thingworx, and used it to bind DS18B20 sensor.
Following is the script I have used to replace existing file in line 57 of 'TempAndHumidityThing':
import w1thermsensor
sensor = w1thermsensor.DS18B20
pin = '4'
temperature = w1thermsensor.read_retry(sensor, pin)
if temperature is not None:
print('Temp={0:0.1f}*C'.format(temperature))
    sys.exit(1)
It gives 'command not found' error
Can anyone please help?
Hi Fred, not sure if this is the complete script, but it seems to be missing shebang something like this #!/usr/bin/env python or #!/usr/bin/env python3 . This goes at the very top of the file containing your python script.
You'll need this while executing the script from a shell to specify Python interpreter to be used
Sushant, I have added shebang, but it is still giving the same error. Is there anything else that I'm missing?
Could you also share which python version and on which OS are you attempting to execute this script? And also how are you executing it? Something like ./<pythonFileName>.py
is the environment variable correctly set for python?
I am using Python 2.7.9 and Unix. The command I'm using is:
java -jar ./temperature-thing-jar-with-dependencies.jar wss://xxxxx.vuforia.io:8443/Thingworx/WS 3c740dfe-df0e-4c85-8ceb-ee3ce7e2ec85
The tutorial to push simulated data to Thingworx worked. But altering the script to push real-time data from DS18B20 gives the error.
I am trying to bind temperature sensor ( DS18B20 ) data to Thingworx platform. I need the script to push real time data from DS18B20 in to thingworx. could you please help me with this script.
